Spyder Timing job, head work, and clutch
b00zt3d spyd3r
571
419
Feb 25, 2016
Lawton, Oklahoma
Well boys she was fun while she lasted. Water pump took a dump on me. Leaking coolant from timing side. Havent pressure tested to confirm, but seeing where the coolant is coming from looks like the weep hole or the pump gasket. Any ways, I'm gonna do full timing job, and new valve seals while I'm at it. What is the "go to" for water pumps these days? Was looking at the gates kit on extreme psi with oem tensioner, but not sure if there's a better option or kit i haven't come across. Also replacing my worn stock clutch. Probably gonna go south bend as I have heard and read good things about. Any ways yall point me in the right directions please. Last time i had water pump and timing components changed was ten years ago and ;paid someone to do it cuz i had no clue about working on these cars I just knew I loved them LOL, doing this on my own this time. Thanks for input.
Well shit... did compression test. Cylinder one was lower than the rest, put oil in spark plug hole and re tested and got higher number as seen in pics. Was determining if i actually needed to replace HG before ripping shit apart. Car runs fine. Definitely needs the new valve seals though according to my spark plugs LOL
The Aisin Water pump has worked well for me. You can buy all Items separate from the kit and get as close to oem as possible. Oem timing belt and pullies are pricey but they last longer.
Just take your time. Its not a bad job, setting timing the first time took me a while. I wanna say that the first timing job I done took me about 4 hours.
Why do you assume head gasket based on these results?
I dont. I guess I should choose my words better. Its getting replaced regardless just wanted to do compression test as ive never done one in this vehicle. Based on these numbers I assume I have worn piston rings on cylinder one. But I tell you, im no expert by any means. Don't really have any other testers like leak down, or coolant pressure testers atm. 🤷‍♂️
I would highly recommend a leakdown. I built one.
Welp, I ended up ripping the motor and trans out and I've decided to do a refresh on it while im at it LOL. whats the go-to on piston rings right now? as I can not find a oem ring set.
Ordered the
KING ENGINE BEARINGS CR4120XPC pmaxkote (racing line), polymer coated; Set
KING ENGINE BEARINGS MB5315XPC pmaxkote (racing line), polymer coated; Set
in standard size.
Still ballin on a budget so dont kill me LOL
Bearings arrived today!!! Piston rings will be here's Thursday! Its almost time!!! Block got a fresh coat of hi temp vht yesterday also.
  • For sale 1g Awd rear calipers
    Have a set ( left and right) rear calipers came off of a 91 talon awd. Freshly rebuilt. Asking...
    • Jowens1185
  • For sale AGT 52MM Bolt-On Turbo Setup
    Selling my old turbo setup, made roughly 52Xawhp/4XXtq @ 30PSI (not officially measured on dyno)...
    • Pushed
  • For sale 2g 2GB Eclipse OEM Fog Light Bezels
    2GB Eclipse OEM Fog Light Bezels $45 + shipping & paypal feesYou must be registered to see...
  • For sale 2g 2G Sun Visor Set ( with home buttons for garage door )
    2G Sun Visor Set ( with home buttons for garage door ) $45 + shipping & paypal feesYou must be...
  • Wanted 2g Tan Door sill trim
    Looking for passenger and driver side door sill trim in tan color. Let me know what you guys...
    • Mahreeoh17
