FIBA Motorsport product updates 1G - 2G - EVO
A few updates on some of the development items
CTS-V 2-piece rotors.
These are now nearing their completed stages. The sample rotor is now cut out (reason for this was also to use it as a display piece)
The bell itself is now printed and waiting to come over with the rest of the development parts I have been working on, bit by bit.
After discussing with some people, it seems as if TWO options are wanted!
  • Version 1 uses the unmachined CTS-V caliper, which makes it a true bolt-on.
  • Version 2 uses a 5mm deeper bell and also the 5mm machined caliper! This is to allow more spoke clearance for people and their wheel setups. I was asked a few times if this was possible. EVERYTHING is possible of course, if the cost is paid and people want the best bolt-on setup going, we've got you.
IGNORE the connections internally! This is ONLY to connect them together. The inside does NOT reflect the actual vein design on the final product!!!
  • You must be logged in to view this image or video.
1G DSM! You got another development item done.
So after the initial V1 and V2 carrier bearing rebuild kits for the OEM housing, I then decided to mock up and work on a full BILLET version, which, as with V1 and V2 comes with a NEW bearing and bearing housing!
This makes the entire setup 100% rebuildable and maintainable for life! V1, V2 and V3 all have life spans in mind and ALL are fully rebuildable! No one offers this kind of service or dedication to the people or for your chassis!
The isolator ring will have some NVH dampening slots as standard and would come in somewhere around the 70 Shore A durometer stiffness. However! Those wanting stiffer connections can use some TPU inserts to close those slots off, creating a stiffer isolator ring!
Then you have options to remove and play around with those inserts to get the right balance, should you wish to do half and half, then that is possible. Can never have too many options.
2G DSM Tubular Front subframes are also getting ready to start back up!
Machined parts should be ready in the next month or so and can get back to producing them fully once again!
So if you wanted one before we moved to the USA then NOW is the time to get on the waiting list!
Something a little NEW for you all 👀
TRIM REFURBISHMENT! 🔥
Not long ago, we were helping a customer who had bought several of our products as part of refurbishing their car. During the conversation, the FIBA Motorsport drip rails came up, and we were then asked something unexpected…
“Can you restore OEM trim and seals as well?”
While this isn’t actually new territory for us personally — as we’ve maintained and restored trim on our own cars for many years — being asked to officially offer it as a service was something new for FIBA Motorsport!
Of course, we said YES and that we would do our best to help revive these aging OEM 2G trim seals and pieces.
What we started with were dirty, faded, grey-looking seals and foam trim that had become dry and stiff over time. Thankfully, they were still usable and flexible enough to save.
The restoration process involves:
✔️ Deep cleaning the material thoroughly
✔️ Reviving and rejuvenating the foam and rubber surfaces
✔️ Removing years of dirt and contamination
✔️ Replacing old clips with brand new ones ready for installation
The end result is trim that looks dramatically fresher, returns much closer to its original OEM black appearance, feels softer and more supple again, and is far better preserved for the future.
Now, it is important to understand that not every trim piece or seal can be perfectly restored. Some may have heavy cracking, splits, or damage from age and storage. These parts will never become “brand new” again — but preserving and restoring them now is FAR better than letting them continue to deteriorate further.
With so many OEM trim parts becoming discontinued and increasingly difficult to source, preserving what we still have is becoming more important than ever for the DSM chassis.
Once restored, proper upkeep is key. Keeping the trim coated, clean, and maintained will help it remain supple and last much longer moving forward 💙
This one is not a product but a service that is going to be offered (along side many other offerings)
We see a lot of people doing Throttle bodies (we also can do those) but no one doing these.
Power steering pumps are old, tired and more than likely have dry rotted O rings and seals inside. The cars are not getting any younger and most still use the OEM PS pump.
This is why we will be offering PS rebuild servicing for them in DSM and Evo's.
1G DSM uses a bunch of O rings for sealing and no ball bearing for the shaft. It relies on fluid for the shaft so keeping your PS fliud clean, regularly swapped out helps keep the pump in top condition!
2G DSM also has O rings but not as many. The body seal is turtle shaped and uses a proper ball bearing which helps and does not rely on fluids to lubricate.
  • Every housing gets stripped down
  • Cleaned of grease and fluids
  • Ultra sonic cleaned twice for a deep clean
  • Glass bead blasted with caps over important areas
  • Pulley also gets painted and refreshed
  • Painted in either black or clear (1G rear housing will be black as OEM)
  • Reassembly with a brand new seal kit (2G gets a new bearing NSK, KOYO, NTN)
  • all new stainless hardware all torqued to specs
Hopefully these will be able to help many people out.
*** 1G pics to follow ***
Bobby, are you able to do these with a core exchange option or are you only doing this as a send in service?
Core exchange can be done yes. Ideally we will just buy the item vs by the time you refunded and all that its more expensive and lpnger then just buying it straight from you LOL
I am missing the trim and clips for 1G rear triangle glass. Can you help?
Not yet no. The clips are going to be the biggest thing going for us for the DSM community since the chassis release! They are also going to be the biggest GB going as the numbers needed to come in are quite a lot to make sure the project is worth pushing forward with.
Some more development work being done. I am no injection molder,
but samples are something we can do to make sure things are of design standards for the next stages.
While assembling an engine for a customer, I took the opportunity to check on a few projects that are planned for the future of the DSM platform and the long-term survival of these cars.
One of the areas we're currently developing is the timing system, specifically the timing tensioner arm and the hydraulic tensioner.
Both of these components are being designed from the outset with rebuildability in mind.
As DSM owners, we all understand that OEM support is only going to become more difficult as the years pass. Parts continue to be discontinued, availability decreases, and sourcing quality replacements becomes increasingly challenging. We experience the same struggles that every DSM owner does.
One advantage we have at FIBA Motorsport is a deep understanding of OEM engineering and component design. While OEM manufacturers were often restricted by production costs, regulations, and manufacturing limitations, we are not bound by those same constraints. This gives us the opportunity to produce parts that not only function like OEM, but improve upon the original design where possible.
Our goal is simple: create long-term solutions that keep DSMs on the road for decades to come.
A key part of that philosophy is serviceability. Wherever possible, our future products will be designed to be rebuilt rather than replaced. When wear eventually occurs, a simple service kit should be all that's needed to return the component to proper working condition, assuming no major damage has occurred. Regular maintenance will always be important, and every moving component deserves attention regardless of how much or how little it moves.
Timing Tensioner Arm​
The new tensioner arm will be manufactured from a stronger and stiffer material than the OEM equivalent while retaining proper functionality.
Features currently planned include:
  • Replaceable bushings
  • Heat-treated base material for increased strength
  • Further hardened pin contact surfaces to improve durability and reduce wear in critical metal-to-metal contact areas
Hydraulic Tensioner​
The hydraulic tensioner is being developed in multiple versions, including applications for 6-bolt DSM and EVO platforms.
Key features will include:
  • Fully rebuildable internal components
  • Easy maintenance through service kits
  • Factory-style operation with improved long-term serviceability
  • Optional refurbishment service through FIBA Motorsport
The objective is to address the growing shortage of OEM timing components and provide a dependable alternative for the future. These parts are intended to perform exactly as Mitsubishi intended, while incorporating the OEM+ philosophy that FIBA Motorsport has become known for within the DSM community.
This is a long-term project and part of a much bigger vision. We want to help ensure that DSM owners continue to have access to critical engine components long after OEM supplies disappear.
Ultimately, we'd love for FIBA Motorsport components to become part of the foundation of DSM/EVO engines worldwide, helping keep these cars reliable, roadworthy, and enjoyable for many years to come.
Oh yeah thats amazing bobby i have 2 new oems ones and just holding onto them. but this will be a well sought after item.
I got a good few spares and of course, the other versions to mock from on the design. Once they do all start to fade out more then we will swoop in and correct the situation with a great reusable product
This post will be getting some more updates in the coming weeks as some developments that have been finished about to be finished.
But for now we want to welcome you to a NEW 1G DSM product!
We have some prototypes we are working on and this is just one of those being done.
These are the 1G DSM PS rack bushes.
Manuals are also being looked into to cover those guys also.
These are a strong and more supportive TPU vs the old soft rubber.
Adding stiffer rack bushes means a better steering experiance and support. check out our little sneak peek video
Below is the pics of the manual rack bush for the passenger side. (Once confirmed fitment these will also be offered up)
1G AWD rear diff support are part of the new 1G developments.
This mid section was made in sections to make it easier for printing and also price LOL. The end item will be 1 piece for the central bar. The ends are still bolt on due to that parts design.
It will come with an off the shelf poly bushing and use an internal centering sleeve and stainless support pad for poly bush support and safety stop.
Some updates on the CTSV rotors and their details.
This is now the last stage and I will start looking into a small batch of these for people.
The Ducts i mention in the video will come a little later on
So today I picked up a full box of 1G rear end parts.
Plans are to mock from some parts to have parts and designs ready and see what we at FIBA can come up with. I know some parts are already done but some parts are not made and we would like to be the first if we can!
So far this was mocked up for the rear Mustache bar. This is a Billet version that is bolt-on and the plans are to have dual use of either Poly bushes or solid/Delrin. so 1 mounting fits both versions.
Just some of the ideas in the brain LOL
Of course some may not come to light (cost can be a factor also on that) but just showing what the brain ticks away on and thinks and when I want to chillout I draw and just come up with random stuff sometimes. Might not be needed but I love to draw and design things. I would love to design my own car one day hahaha
This is sick, I love the design just wondering how it will hold up with the bolt on pieces on the ends
No different. They are M10 and four of them. They together are stronger than the 2 OEM M12 bolts so will not have any downfalls. The bar could be all in one but the machine time and costs would be a bunch more.
Another problem solved. Another discontinued part brought back to life.
This is exactly why FIBA Motorsport exists.
A fellow DSM owner reached out on the DSMtuners forum after hitting a brick wall trying to restore his 1G DSM. The problem? An often missing or worn-out steering rack bushing on a rare manual steering rack — a part that has been obsolete for years and simply isn't available anymore. Neither are the power steering bushes for that matter.
Rather than accepting defeat, we worked together to change that.
After reverse engineering the original components, many discussions and measurements, we have successfully developed brand-new replacement steering rack bushings for BOTH 1G DSM steering rack versions:
Power Steering Racks MB315228 + MB501119
Manual Steering Racks MB315228 + MB315179
The manual rack was by far the biggest challenge. The passenger-side bushing is completely unique and shares virtually nothing with the power steering version, meaning it had to be designed from scratch.
After careful measuring, prototyping, and engineering, we're pleased to say...
We nailed it the first time.
That doesn't happen often! Engineering is normally a process of prototype after prototype until everything is perfect. It's exactly why we insist on developing and testing every product properly before it ever reaches our customers.
Material Matters
These bushings are manufactured from a high-quality TPU material with a hardness close to 85A durometer, providing an excellent balance of durability, compliance, and long service life.
(Yes... we even own a durometer tester!
When you're reproducing discontinued OEM parts, knowing the original material properties is just as important as getting the spec right and making the adjustment to the improved durometer.)
A huge thank you goes to Gavin (DSMtuners: @gavingsx for trusting us with this development for his rare manual rack and helping us make this project possible. Because of his willingness to work with us, every other 1G DSM owner will now have access to a solution that simply didn't exist before.
Coming Soon!
We're planning to release these on the website within the next week as a Pre-Buy.
Both versions will be available:
Power Steering Rack Bushings
Manual Steering Rack Bushings
These will not be regular stock items initially. Production will begin based on pre-buy demand, helping us determine the first manufacturing batch quantity and ensuring everyone who needs a set can secure one.
As always...
Innovation Starts Here.
#MB501119 #MB315228 #MB315179 #fibamotorsport #InnovationStartsHere #1GDSM #1Gsteeringrack
Count me in for the power rack Bobby. What’s the pricing?
Looking into that now. I am looking into both injection-molded prices and the printed ones prices. Both have pro's and cons of course but will see what can be done.
Currently, the high-quality printed versions are going to be about $105 EST for the pair once shipped to me.
I want to bring that down, but it is why I want to look into injection molding tooling, as long as I can secure a decent number of people, it will be worth doing that tool to them get the prices down some more. Thankfully, the design is not complex, so we will see what it comes back as price-wise.
Been getting prepped and ready for the shootout and soo much to pack and do! Along with moving house this month also!
Well just showing both these versions are going to be with me at the show and the AWD Manual W5M33 plates are done.
Next up once I get ahold of them are the AWD auto plates and also the 1G 6 bolt plates
