roadtrip_69
- 68
- 9
- Apr 18, 2008
Cincinnati,
Ohio
Anyone have the Mitsubishi part numbers for the 3g/Evo Mass air flow sensor?
My 2g died. Well it literally broke from heat and over tightening the clamp on it and got sucked up into my compressor wheel and beat up my brand new FP 68hta. So I figured if I'm replacing it I might as well upgrade. But looking through RockAuto. There seems to be different part numbers depending on if I look up an EVO or a 3G. There's also (4cyl 3g and 6cyl 3g) So there seems to be some difference between them?
Which one/year should I get that works the best? Tuning isn't an issue I have Ceddy Mods and there's an easy setting to switch to it. And I'll pick up a pigtail on eBay.
Also I currently have a K&N Cone Filter on my 2g MAF will it still fit/switch over to the 3g/EVO?
And the aftermarket air intake tube between the MAF and turbo, will that match up as well?
Thanks to whom may know these answers
