DogWhistle
Supporting VIP
- 1,164
- 751
- Sep 13, 2012
St. Paul,
Minnesota
Our Fuel Lab APR pressure reading has a problem. It now reads "0" and the car idles and drives well.
Last Fall, before the car was stored, we noticed the indicated fuel pressure reading would fall to about 22psi after running 42psi for more than 5 minutes, with no change in engine behavior. After we addressed a pinhole leak in the return line, we checked fittings -- no leaks. We replaced the diaphragm with the Fuel Lab kit twice and even tried it with and without the vacuum line attached. No change in behavior.
Has anyone else experienced this? Will replacing the gauge correct the reading, or should we just get a new APR? Should we stay with Fuel Lab?
Thoughts please!
Thoughts please!
. Now I'm sure your gauge doesn't look like that! But the point is these things can fail and they are not very fail-safe.
