TheMadCheshire
20+ Year Contributor
- 200
- 8
- Mar 8, 2006
Elizabeth,
Colorado
Everyone, meet Gary, the grey Galant. A poor abandoned Galant vr4 that was sadly, unloved. Picked up by a tow company, sat in their yard for a while and eventially sold to your's truly.
Initally called the sh!tbox, because that's what i was, I eventually became fond of this turd and started to call it "Gary"
It was grey, or rather gray. But both were a play on "Gary". So it stuck.
This was the first auction car i had ever purchased. Unprepared and unaware, i still managed to finagle this turd out of the auction yard without damaging my truck or trailer.
Once aquired, the inspection began. Sooooooo much sun damage.
The paint? cracked and worn, the rear seats? literally the fabric cracked, peeling, melted and well... gone.
The window sealant? Also, literally, melting away.
The worst part: it didn't start.
Years(i'm assuming) left the car with damage to it's wiring and in an inoperative state. After fixing all the wiring, the car still did not start. I'll save you the diagnosis, but a spare ECU later and Gary fires up.
Small fixes here and there, and well, now Gary runs/drives and well, does car things.
Knowing i didn't want to put too much money into this, it stayed mostly as it was: 16g, 550cc injectors, ecmlink, 3.0 exhaust, bigger intake and a FMIC. Evo struts installed not by me and were ok, still on it, i'm not a total fan.
Fixed things as they broke for about a year.
Then. It hit. What to do with this car. We already have a 6g72 swapped into our rallycar(and it's still awd).
What about the Turbo model? For sure this will fit. For sure i can make it work. And welp.
I did.
It runs, it drives, it does car things and most importantly: it makes turbo noises.
What will follow is the build of this car. I tried to take pictures where i could, i have all the information i think necessary. Now this was a process. And so will this thread be. I wouldn't expect more than weekly updates.
So if a 6g72TT swapped GVR4 is your thing, buckle up and occasionally check back as i post the process, troubles, wins, fails and mods needed to make this dang thing work.
Here's a teaser pic of the final thing, and yes. I have been driving it. it does work. And boy howdy was it worth it.
This is the Build Thread for Gary, the gray Galant. Reply below.
I did.
