DSM Mechanic for hire in the San Diego area
Yeah don't know what scrilla means either LOL I'm just gonna assume Kris is referring to money. I've decided to have Kris finish up the GST and get me to my goal of 500 whp. After I get back from the shootout is when things will start happening.
Hi Kris, do you think the 350z(touring edition) brembo calipers can be adapted to the 2004 and up Nissan quest? if it will work, how much would it cost to put it on and what parts will I need other than the calipers?
Talk about a random question that doesn't quite work with a dsm. I know Kris specializes with dsm and not Nissan. I'm sure a 350 forum could point you in the right direction
just wondering if it doable since I think those brembos are probably similar or maybe the same as the evo brembos and hoping that Kris would have an idea and if its the about the same process of adapting the evo brakes to the eclipse.
not a lot of available aftermarket parts for the nissan Quest so Im just going with bigger rims(18 OEM) and brakes.
Im still in the freelancing business people let me know all your dsm needs.
I will not tune a car without a wideband. preferable one that is not an aem but I can make do. Prior to the tune it will be the owners responsibility to make sure there are no boost leaks. I can do a boost leak test for you but it will be an aditional 50.00. If you would like to make the wideband log in link(my preference) I can set that up for an additional 50.00 with the tune(this charge is for aem wideband logging only all others are easily setup). any other inquires feel free to ask through pm's.
I too can say that Kris is the MAN when it comes to our cars not only does he go far beyond our requests but he is ust a all around good guy. He has been the only one to touch my car from the very beginning of its new life and everything has been perfect. Best part is we about to finish so i can make some runs at Quailcomm and represent Kris's awesome work on the track.
Let me know when that happens I'd like to see it in action.
Well it might be the next Qualcomm coming up depending on if everything goes smoothly. Gotta do the LC1, Boost leak check, maybe rebuild the Throttle body to fix the shaft leak, try and get a FPR but thats depending on what Kris says, Battery holder, and some safty checks here and there, and try and get a custom upper IC pipe made. My buget is getting tighter and tighter so I'm crossing my fingers.
Do you not have time to do that turbo swap, or maybe just dont have the know how. Let me give you a hand. I can do it all1g,2g,awd,fwd,head swaps,fmic installs, transmission rebuilding, engine rebuilding, electrical troubleshooting, and ecmlink/SAFC tuning. just hit me up with a pm for an estimate. have done work for a few members. lots of work on Gofer's car,lots of work on goodbuds car currently rebuilding his motor, and many more. sorry no body work other than that nothing too small or too big let me do it right the first time.
Hello Sir. Are you still in San Diego by any chance? I’m looking to get my DSM repaired.
Hi if your still fixing dsm i really need help i am around mira mesa area
http://www.dsmtuners.com/threads/need-help-pls.484292/
I dont want to sell my car so if you could help me fix this problem much appreciated! Thanks tou can pm me
Were you able to find someone to fix your car? I’m looking for someone to help me with mine as well, thank you
