Street Build
95 GST 6-bolt Swap
95 GST Eclipse 6 bolt Street
Ownership Status
Currently Own
Mitsubishi Eclipse GST
Turbo Type
50-trim
Drivetrain
FWD
Build Type
  1. Street
47trim Turbo, 650cc Injectors, 9lb Flywheel, 450 Walbro fuel pump, 3G lifters, 6-bolt block, FMIC, CarbonFIber hood and tail lights, projector headlights, MAF translator, 1g intake manifold and headers. Greddy turbo timer, Greddy boost controller.
Mods-Engine
47t turbo, 650cc injectors, 450 walbro fuel pump, new fuel filter, fuel pressure regulator guage(pending), 3g lifters(pending). 93 6-bolt block on 95 gst body.
Mods-EMS & Logging
obd2 reader, maft 2g translator, AEM obd2 sensor gauge.
Mods-Drivetrain
Clutchmaster 9lb Flywheel. Clutchmaster Stage 2 clutch.
Lowering Springs, front and rear upper sway bars, poly motor mounts.
Parts Wishlist
AWD transmission, Racing axles, New hub bearings, msd ignition, 5lb nitrous kit
Background
I got this car back in 2007 with the 6 bolt swap already in it. 180k miles it needed some tlc. It ran smooth for about a year but the sensors/wiring and the suspension was in need of a tune up. I started upgrading it over the years when i had the money. Its been through a rough life of being outdoors and 2 accidents. Deer messed front end up i swapped core support from shell. I got side swiped my buddy pulled corner panel out and fixed the body. I repainted it flat black from the deep green. It sat forever when i went to jail for dui. Mice chewed some wires. Ive been fixing the harness as much as i can. It runs but battery issues. I have spare harness for parts. I upgraded the turbo to a mitsubishi 47t turbo back in 2008 still strong. I have a extra 4g63 block that i plan to build and install. Funds are an issue for me right now so the build is taking time. I plan to take it up to my buddies shop and start pulling the motor and trans to make it awd. I still have a bunch of new parts to put on.
