Activity Feed
Live updates
  • 1990TSIAWDTALON replied to the thread 2G First Gear Pops Out.
    · 67 3,199
    I use a Jacks Race transmission that they no longer offer. It was pricey but it has been a good piece so far but TMZ is the most stand up man and would be my goto now days, if he has time. 👍
  • dwb replied to the thread Is this car worth buying?.
    · 6 152
    Sorry, did I just see $10k, not $1k? Yikes.
    · 6 152
    Likely a 6 bolt/4 bolt combo, which is a desired 1g. Fairly low mileage and appears to have been garaged. I can't make out much on the specs but on first glance and for $1000 it seems decent, depending on rust. Knowing it's a project, if you have...
  • 92AWDHX40 replied to the thread 1991 Eagle Talon TSi.
    · 15 574
    That was your dsm at the shootout I saw a few of us Paul and dusty and pjj and the Morrisons.
  • GIB replied to the thread 2G First Gear Pops Out.
    · 67 3,199
    Out of curiosity what happened with Jacks? Did they go down hill? I remember when his shop was the go to for transmissions.
  • victorgalant posted the thread Is this car worth buying? in The Hangout.
    Hi guys, recently a 1g GSX just appeared on my marketplace, and that not a common sight where I live. They say it's a 1992 GSX, here are the pictures. The car is dissasembled and wasn't finished because of "lack of time"Any advice is welcomed...
  • 1cleangsx replied to the thread 1991 Eagle Talon TSi.
    · 15 574
    Nice job! What clutch are you running?
  • BTKai posted the classified ad For sale 1g MD122260 Forward Facing Oil Filter Housing in DSM Parts Classifieds.
    Up for sale Discontinued MD122260 Forward Facing Oil Filter Housing $150.00 shipped plus paypal fees if you have any question please let me know! You must be registered to see element.You must be registered to see element.
  • tschuhly replied to the thread 2G 7 Bolt Oil Filter Housing Oil Cooler Sandwich Plate.
    · 4 181
    I don't have the spacer but I just measured the sandwich plate itself and it's about an inch and 1/8.Also I shopped around price wise and I think I ended up getting mine from summit racing.Also, to answer your other question about what the...
  • steve replied to the thread 2G Injectors not firing.
    · 19 531
    Both measurements don't seem correct. The signals should be 0 to 5v not -2 to 4.3v or 0 to 10.9v. It's good that you see pulses but I'm scratching my head on the levels. The ECU should be outputting about 5v on both signals and the CKS and CPS...
  • MindBlowin03 replied to the thread Keltalon is still active!.
    · 6 271
    Nice! Looking forward to the next setup.
  • MindBlowin03 replied to the thread Cheap(ish) Valve Cover?.
    · 5 179
    I second this. I spent a ton of time prepping and painting a cover only to have it crack on that same spot. I JB Welded it and haven't had a problem in years.
  • Vladimir replied to the thread Cheap(ish) Valve Cover?.
    · 5 179
    I know everyone is gonna hate this but: You must be registered to see element. It's super cheap and works if done right. Can get you by till you get your finances straight
  • DSMPT replied to the thread Cheap(ish) Valve Cover?.
    · 5 179
    That's the most common spot to crack by over tightening. The valve covers of the early DOHC 4g61/63/64/67 are interchangeable regardless of turbo or non turbo. (Not the late 4g6 covers, like EVO 4+) Should search for a fair price good used one...
  • victim posted the thread Cheap(ish) Valve Cover? in Maintenance & Repairs.
    Ended up cracking my valve cover while attempting to retighten the bolts and used the wrong torque, Seems messed up enough that I will need a new one and was wondering if theres any better spot to find a matching valve cover for the 4G63T, only...
  • Miasma replied to the thread 1998 Eagle Talon TSI AWD.
    · 29 4,274
    August 2026 Update – More Heat Issues, Throttle Body Rebuild, and Window Switch ProblemsTo start the month off, after cruising around and doing a couple of pulls, my driver's-side 12" SPAL puller fan melted again.I thought I had previously...
  • cswindel replied to the thread 2G 7 Bolt Oil Filter Housing Oil Cooler Sandwich Plate.
    · 4 181
    @tschuhly do you have the spacer too? It looks like if I run the spacer I might just be able to stack them together and use the oem OFH bolt without needing to mod it. With my little bit of research it looks like the bolt is 1.75 in long and the...
  • jersygsx posted the classified ad For sale 4G63 6 Bolt Timing Cover in DSM Parts Classifieds.
    6 Bolt Timing Cover $75 + shipping & paypal fees* this was used in a 2G so the hole was opened up for the 2G Driver MountYou must be registered to see element.You must be registered to see element.You must be registered to see element.You...
  • jersygsx posted the classified ad For sale 2g 2G OEM AWD Manual Driver Front Axle in DSM Parts Classifieds.
    2G OEM AWD Manual Driver Front Axle $80 + shipping & paypal feesYou must be registered to see element.You must be registered to see element.You must be registered to see element.
  • jersygsx posted the classified ad For sale 4G63 6 Bolt Oil Pump Pickup in DSM Parts Classifieds.
    6 Bolt Oil Pump Pick Up $60 + shipping & paypal feesYou must be registered to see element.You must be registered to see element.You must be registered to see element.
