Activity Feed
Live updates
  • steve replied to the thread ECMlink Need help finding the problem.
    · 3 130
    Please check the last few post in your other thread. There is a good chance your MAP sensor is dying.
  • jacobdsm7 replied to the thread Street Build Project 9s: Street Driven 98 Eclipse Auto.
    · 138 21,137
    oh buddy are you about to be a wealth of information for me! read the entire thread - alot learned here.
  • dwb replied to the thread ForcedFour Time Capsule.
    · 56 4,803
    Since your intercooler/piping is all aftermarket according to your build, I doubt you have another port, but always worth a look. That would be ideal for boost control but maybe not feasible right now. Eventually you could tap a port into your...
  • 92AWDHX40 replied to the thread 89 RAM 50 4g swap "Validation Plan".
    · 130 26,361
    Oooh looks good man I want another ride this fall please
  • jdxnc replied to the thread What did you do to your DSM today?.
    · 12,064 826,711
    It was definitely on a much faster pass, without the pedal around the 3/4 shift, the 121 1/8 mile trap shows it was 150+. I'll get there! This car has typically short tracked really well, on the Mitsutimes lists I'm usually 5 or so MPH lower...
  • Detail posted a question on the classified ad For sale 2g Eclipse/Talon AWD Partouts.
    Want to ship a dash to atlanta? Lol
  • 1990TSIAWDTALON replied to the thread What did you do to your DSM today?.
    · 12,064 826,711
    9.4 ain't bad man and at 140. I can trap 121 so far. :thumb: (on a 2.3 60' :oops: )
  • Tiki2777 replied to the thread 2G Fuel pressure fluctuation.
    · 62 1,652
    That Toyota/Mitsubishi grommet can ABSOLUTELY slide down/get pushed off of the barb/nozzle, which is why I abandoned ever fully implementing it-great point (If you fight with it long enough it'll slip off the Walbro 450 style nozzle barbs, which...
  • Hopefully every gallery plug got removed and all of the oiling system cleaned out in the block and head.Im sure you did the crank, they all like to store hidden lill surprises.I’ve lost brand new engines to this - assuming the machine shop...
  • opn0 replied to the thread ForcedFour Time Capsule.
    · 56 4,803
    Nah, just stock.I'm saving for pillar pods, but I don't make a ton of money so it's taking a while :cry:I'll poke around tomorrow, but I haven't seen a port that I remember.Yep! TB -> Boost controller -> wastegate actuator.And just to...
  • pauleyman replied to the thread What did you do to your DSM today?.
    · 12,064 826,711
    Made progress today. Wanna guess which valves hit?You must be registered to see element.Oddly none of the valves look bad. Haven't done any testing. Betting this thing would've run with a new belt. Not 100% but it might have started. It was...
  • miliman13 replied to the thread Resolved New 2G rear LSD CV axle option!.
    · 36 24,394
    Let’s us know ; once your running if you have any leakage from those small gaps .
    · 56 4,803
    Actually, thanks to google image search, I found your blue/black box. It looks like a MAC 3-port boost controller that resembles this: You must be registered to see element. You must be registered to see element.Hopefully you can find a port on...
  • We're on Boost replied to the thread 2G Fuel pressure fluctuation.
    · 62 1,652
    Oh yeah, like Steve said, your Omni 4-bar quit working right there at 138.034 secs. Display the raw voltage for it, "RawOmni4Bar". It goes to 0.02 volts at 138.034 and stays at either 0.00 or 0.02 volts all the way until the engine quits...
    · 12,064 826,711
    Finally published a video for my first, mostly successful pass on the new buildYou must be registered to see element.
  • Thanks for all of your help guys!Just got the head back from the shop and it was still within spec thank god, they said the same thing that @twicks69 said, they think that someone put the head on and THEN tried to turn the cam sprockets to...
    · 56 4,803
    The stock boost gauge is just an ecu calculation based on airflow. It doesn't actually have a boost source. Do you have an aftermarket boost gauge, and if so, what is it (brand/model)? It might be electronic with a sensor somewhere. If you don't...
    · 56 4,803
    Yeah three of the four are capped. The P port was what my BOV was originally hooked up to. I unplugged it and then the port started sucking air in.And when you say boost gauge, do you mean stock boost gauge or aftermarket? I frankly don't know...
  • GJP396 replied to the thread Resolved New 2G rear LSD CV axle option!.
    · 36 24,394
    Awesome to hear everything went together. Also nice to be able to help out on here, I'm pretty sure we would never have finished our car without all the information here......
  • 2GbTalonGuy replied to the thread What did you do to your DSM today?.
    · 12,064 826,711
    Went to a meet/cruise at the theater for the 25th anniversary showing of the fast and the furious and met a couple other DSM owners there.You must be registered to see element.You must be registered to see element.
