Activity Feed
Live updates
  • bastarddsm replied to the thread 1G Gear identification help.
    · 6 483
    I don't keep teeth counts memorized, but looks like you have a early and late 4th, and a late and early small synchro 5th.
  • 1990TSIAWDTALON replied to the thread 6266 Build or Bust.
    · 724 76,805
    If it works then 🤷 :hellyeah:
  • 1cleangsx replied to the thread 6266 Build or Bust.
    · 724 76,805
    UPDATE!!! Fuel leaks fixed! With orings lolYou must be registered to see element.The filter housing has a chamfered end, I test fitted either side with an o ring hand threaded in all the way then backed it out, it wasn’t chewing up the o ring...
  • tschuhly replied to the thread 2G stuck in limp mode.
    · 79 3,029
    Alrighty, here is the update: -I did a boost leak and got everything post MAF to seal up. There is a small leak at the adapter plate for the filter but that shouldn't matter. -I tried unplugging the MAF with the car running and it didn't seem to...
  • We're on Boost replied to the thread 6266 Build or Bust.
    · 724 76,805
    Could you post a link to the STM page you bought it from?
  • IHeartMyHonda replied to the thread ECUflash ECU Flash.
    · 8 574
    I was able to do similar things with mine. I used an aem wideband to simulate the narrow band and was running e85
  • steve replied to the thread ECUflash ECU Flash.
    · 8 574
    Whatever you think might be of value. Even if it's compiling references to existing posts for most of it. This is your chance to shine since you offered :)
  • GhostTypeP0300 replied to the thread Resolved New DSM P0300.
    · 82 4,674
    Ok so I’m definitely a firm believer in doing my maintenance first but I think my main goal is to get it to pass smog and light inspection first.I test drove the vehicle and it had no check engine light car drove great.The next day I noticed the...
  • tyvo98gsx replied to the thread ECUflash ECU Flash.
    · 8 574
    Gotcha. I know there are a couple threads on the basics like downloading ceddy mods and what not. I guess this would be aimed at more advanced/nuanced questions.
  • Anfurnyy posted the thread 1G Gear identification help in Drivetrain Tech.
    Bought a box of miscellaneous transmission parts awhile ago and trying to throw together a spare 3/4 setup and found these odd balls.- #1, 2, 3 all fit small synchro and the "HD" 3/4 hub and slider. #4 does NOT.- They do NOT fit double or...
    · 724 76,805
    Only if the housing is leaking. It is probably just the fitting on the end but IDK what filter STM had sold you.
  • ashervaleriano replied to the thread Colorado 2G Eclipse GS owner wanted!!!.
    · 8 562
    Not at all! Thank you for helping me clarify that any 2nd generation eclipse will do!Thanks so much your help! Unfortunately I’m busy today but I would’ve loved to see the meet there. I’m still new to this forum but I’ll do my best to DM you.
  • steve replied to the thread Tune a 2006 Mitsubishi Eclipse?.
    · 2 290
    I'd think that's a better question for You must be registered to see element. since an 06 Eclipse isn't a DSM.
    · 8 574
    I don't but I'm sure even a basic walk through of how you tuned yours would be useful to somebody trying to get started.Sometimes my role is to just move the discussion along.
    · 724 76,805
    That makes sense, I guess I need to replace the filter housing and the fittings?You may be right, the fittings I have I bought coupled together with the filter from stmtuned
    · 8 574
    Is there something specific you have a question about?
  • 92AWDHX40 replied to the thread Tune a 2006 Mitsubishi Eclipse?.
    · 2 290
    There is nothing to tune. No need for anything on that platform. You'll have to go to the forums for that.
    · 724 76,805
    I went and pulled out a new, inline, fuel filter and it doesn't use orb fittings. None of my cars have a oring on the filter except for the canister itself, on the end caps.You must be registered to see element.
    · 8 574
    Any insights would be welcome. As you mentioned there isn't a lot of info.
  • Tony1094 replied to the thread 2G 96 EU Oil pan temperature sensor.
    · 15 733
    Could always get a new oil pan and a sandwich plate for the oil filter and have multiple spots for sensors. That's what I did anyway.
