Activity Feed
Live updates
  • TasosEclipse replied to the thread 2G Oil leak.
    · 80 2,697
    When I took off the spark plugs they were black and the valve seals I change them now.
  • Anfurnyy replied to the thread 2G Oil leak.
    · 80 2,697
    Smoking on decel usually means valve seals. The vacuum inside the engine / intake ports is pulling oil vapor through the seals. Could also be valve guides as well. Can you check inside the intake and exhaust ports and look at the valve stem and...
  • DSMPT replied to the thread 2G Oil pump timing.
    · 9 540
    If you have the balance shaft belt (the small one) you still have the shaft. Like Bobby said above, if the LH shaft has been eliminated, you can't feel centrifugal force by the balance shaft counterweight when you spin the oil pump sprocket...
  • FIBA M - EC17PSE replied to the thread 2G Oil pump timing.
    · 9 540
    You can check the rear BS bolt plus on the back of the block as a way but also if you spin this without a belt on it you can generally feel if the BS is connected or not due to how lighter the sprocket is to rotate vs with the original balance...
    · 80 2,697
    Please help I checked everything…
  • 4g63Sneaky replied to the thread 2G Oil pump timing.
    · 9 540
    I bought the car about 6 months ago. Is there anyway of knowing if the balance shaft was eliminated? Also would it be okay if I just set the time for the oil pump cause right now as it sits everything is in time except for the oil pump?
  • MindBlowin03 replied to the thread Weekend Warrior - 1997 Talon TSi AWD.
    · 48 5,988
    Finally had some time to pull the trans and dive into it a bit. Pretty much what I expected, stripped second gear and broken 1/2 shift fork.At this point I'm pretty sure I'm going to go with a PAR straight cut synchro set. I have a spare built...
    · 9 540
    They have a different part number, so it would depend which one you buy. Original is what I said above.
    · 9 540
    All come with an arrow now from Mitsubishi, building and engine for a customer and his OEM pump uses an arrow and is a 7 bolt also just to note.I have seen both but most of the 7 bolts I have noticed are arrows my old OEM pump
    · 9 540
    The blue circled dot on oil pump sprocket is the timing mark for you. The early oil pump sprocket comes with an arrow, and the late sprocket comes with a dot. So in the pic, it's off, but keep in mind that all timing marks (cams/crank/oil pump...
  • Joh_ecp97 replied to the thread 2G Crank no start.
    · 5 368
    And to clarify I purchased the car with DSMLink v2 already on it. I have the cord for the tune from previous owner but not the physical disc or ECMTuning account info so I cannot access the tune even if I wanted to could anyone help me with any...
    · 5 368
    No, I have the cord to do so but I don’t have the disc or the ECMTuning account info from previous owner
  • pksystems replied to the thread So what are you working on that’s NOT your DSM?.
    · 1,785 168,724
    Finished gluing the front section of bumper together. It looks pretty massive, but it is the correct size. I may change the route I was originally going. I was going to block sand the plug smooth, pull a mold off, and have 100% carbon body...
  • miliman13 replied to the thread 2G Transfer case leaking between mating surfaces.
    · 3 302
    Cool thanks for confirming!I was wondering if perhaps 🤔 it’s only leaking from one of the bolts You must be registered to see element. And it makes it look like it’s the whole surface You must be registered to see element.You must be registered...
  • DSMPT replied to the thread 2G Transfer case leaking between mating surfaces.
    · 3 302
    That is correct. And I have never had a leak from the mid/rear housing seal by RTV. I don't know your case if it's actually leaking from the mating surface of mid/rear housing or not, but one thing it's common is when you overfill the t-case...
  • jdxnc replied to the thread 2G Transfer case leaking between mating surfaces.
    · 3 302
    Between the front housing and the mid housing, there is an o-ring, which sits around the boss on the mid housing and seats into the receiving groove in the front housing. The metal shim is just that, a shim that sets the distance of the gears, it...
  • miliman13 replied to the thread 2G FIC 2150 injectors with Radium fuel rail.
    · 12 862
    Those are not the spacers you are looking forYou must be registered to see element.
  • So it would appear that i am leaking from the mating surfaces !!!The Tcase and tranny each have their own unique oil color - so Im not confused and no it’s not the in/out-put seals.Theres a bead on the center housing i suspect it leaks from...
  • athlete3344 replied to the thread Long awaited decade long project.
    · 35 4,146
    Rear main seal done, oil squirters next. Need to get engine accessories organized, bolts accounted for, prep mounts for paint, etc.Will prob work on front case in parallel. Need to start reading into degreeing cams.You must be registered to...
  • 92AWDHX40 replied to the thread Goonie’s 90 GSX.
    · 232 41,752
    Alright man there you go see you at the shootout. You gotta take me for a spin
