Activity Feed
Live updates
  • Joseph E replied to the thread GVR-4 Galant vr4 vs other options.
    · 9 445
    Ive been looking into importing an evo 6 aswell, most people tell me that the galant is just not worth it. I will give it some time so i can think on it but im leaning towards an evo.Is the chassis that big a of a difference? I was under the...
  • Free to a semi-local DSM'er who can use it; picked up in Watertown, WI.2.5" Buschur Cat-back exhaust with Vibrant polished SS resonator and Dynomax Ultraflow SS muffler.It is covered in fluid film and dirt/grime, but will clean up decently...
  • jesse12345 posted the classified ad For sale 4G63 1000cc fic injectors in DSM Parts Classifieds.
    Injectors are like new I used them for one summer. Resistor box eliminator plug included. The last time I ran them was with 91. I no longer have a need for these.
  • Justin DuBois replied to the thread 2G SRS diagnostics today.
    · 10 542
    The horn also goes through the clock spring - the horn is working. I am suspecting something else.
  • diambo4life replied to the thread Drag Race Build Project 98 Eclipse.
    · 127 16,419
    Baby pull here on wastegate. Still tweaking the tune. Feels pretty slow to me still....lol, but I don't want to get greedy with this Amazon fuel pump by turning it UP. This is on 19-20psi roughly and it's on E85 so the timing is still very soft...
    · 127 16,419
    A couple minor changes made. My Rockauto coil pack took a dump on me a couple weeks ago when I made my first pull. The car stumbled and started misfiring. So, I swapped the old coil pack on the car and the car is running much better. My rear...
  • pma1123 replied to the thread PMA1123's Talon.
    · 19 1,549
    Managed to blast/prime/paint these items over the weekend.You must be registered to see element.
  • diambo4life replied to the thread GVR-4 Galant vr4 vs other options.
    · 9 445
    There is no comparison between those two. The EVO will eat the Galant in every way. Can also make more power in stock configuration. As mentioned, the issue with these cars has become availability of replacement stock parts. The aftermarket was...
  • Set of 4 RCI/SouthBay Bosch fuel injectors. These are 2200cc high Z injectors that have clip-on adapters for DSM/Evo 4G63 (and Honda, I believe?). They are over $700 new and good for massive power. I bought them lightly used but downsized my...
  • 1990TSIAWDTALON replied to the thread Hello from a Mopar guy!.
    · 8 388
    4g63 swap those vehicles and get a real kick out of it! ROFL Welcome to the forum, we are all here to help as much as possible 😊, glad to have everyone. Marty
  • 1990TSIAWDTALON replied to the thread How to Bleed your HLA's (lifters) 👍.
    · 13 918
    I usually build 2 a year and have for many years. I've never had the issues you have seen multiple times. ✌️ Even if I had, a rocker is a easy fix, a bent valve is not an easy fix and I DO recommend this if you are rebuilding one. Everyone has...
  • INVUJerry replied to the thread Hello from a Mopar guy!.
    · 8 388
    Thank you! I figured this was more 4G related, but figured I could find all sorts of info here. I did see a couple forum posts from 2013 of someone putting a 6g75 into a Plymouth Acclaim, mainly just needed to make a compatible passenger mount...
  • SixBolt_16G replied to the thread Hello from a Mopar guy!.
    · 8 388
    Welcome!
  • chrysler kid replied to the thread 2G SRS diagnostics today.
    · 10 542
    In my experience the module is always the fault underneath the center console. I have typically just unplugged them and the light will turn off on its ownA few months ago there was some one in Europe in the newbie forum trying to diagnose it...
  • 19Eclipse90 replied to the thread What did you do to your DSM today?.
    · 11,949 764,500
    M10 x 1.25.
  • chrysler kid replied to the thread 2G Oil return line leaking.
    · 10 506
    The other variable is that one of the bolts may be too long to seat the contact on the turbo. The aftermarket hose style returns that I run always have a thick drain plate to the turbo where as the oem ones aren’t as thick. If I recall...
  • chrysler kid replied to the thread 2G Drain behind the fuel door curiosity.
    · 3 295
    The only other logical variation I can think of is that all of my 2g cars always had a sunroof and never had that drain. So maybe hard top cars had a drain there for some reason, or it was an early 95 thing
  • chrysler kid replied to the thread GVR-4 Galant vr4 vs other options.
    · 9 445
    So to me they are totally different cars, the evo will have kids coming up to you at the gas pump to take pictures of it, and people saying wow is that an evoThe vr4 is going to be the niche car that gets attention from the serious car people...
  • chrysler kid replied to the thread How to Bleed your HLA's (lifters) 👍.
    · 13 918
    I’ve seen multiple occasions of the lifters never filling and cars taking up to 50 miles to properly fill the liftersI’ve seen multiple issues of the rocker arms coming off of the lifters because there is no tension on them when installed. The...
  • Ralph-RaccooN replied to the thread Hello from a Mopar guy!.
    · 8 388
    Look at the scale of the K-wagon and the small SUV in the same image. cars today a fat retarded blobs. I like the NYG Neon. I have a Shadow ES and Lancer Shelby myself. I assume your on Turbo-Dodge.com and or turbo-mopar.com
