Activity Feed
Live updates
  • 1cleangsx replied to the thread Street Build Project 1g (NBA DSM).
    · 378 53,546
    Hey man I gotta say I love your car, and I just noticed your from Virginia, I graduated high school in Fredericksburg, my mom and brother live in Richmond, along with detective coating lol, anyways it’s nice to see a CLEAN East Coast dsm, keep it...
  • Colin rosti replied to the thread 2G Clutch dragging.
    · 2 188
    Thanks, im going to give this a try tomorrow I’ll let you know how it goes.
  • 2G Power Door Lock Actuator Set $70 + shipping and paypal fees* mounting hardware includedYou must be registered to see element.You must be registered to see element.
  • jersygsx posted the classified ad For sale 2g 2G Gauge Cluster Dual Gauge Pod in DSM Parts Classifieds.
    2G Gauge Cluster Dual Gauge Pod $25 + shipping and paypal feesYou must be registered to see element.You must be registered to see element.
  • jersygsx posted the classified ad For sale 2g 2G Power Mirror Set in DSM Parts Classifieds.
    2G Power Mirror Set $40 + shipping and paypal fees* I believe these are Barcelona Red in color * not flawless but respectable shape for 30 year old side mirrorsYou must be registered to see element.You must be registered to see element.You...
  • steve replied to the thread What did you do to your DSM today?.
    · 11,796 718,700
    Do yourself a favor an replace the old metal ISC before a coil shorts and damaged the driver. It's cheap insurance.
  • jamel16 replied to the thread Street Build Project 1g (NBA DSM).
    · 378 53,546
    Update: Finally got the exhaust buttoned up and I’m pretty satisfied with the end result. Instead of the resonator , I incorporated a megaphone piece. I have been researching how these affect the tone, so I’m experimenting with this one. I welded...
  • verified hick replied to the thread FIRST DSM STREET BUILD!!!.
    · 379 49,750
    You must be registered to see element. well men and more men. it does run. i still gotta put the belts on, coolant, hit it with a timing light. a boost leak test and then see what happens. although when it was running it was still smoking out the...
  • Justyn replied to the thread 1G A/C condenser.
    · 3 211
    Where in ocala are you?Here’s the deal I’m looking for one here in Canada, unfortunately I can’t find one. So I seen partsgeek was selling it on eBay because they don’t ship to Canada. Partsgeek shipped it out, and eBay lost the condenser. So...
  • TerminalTalon replied to the thread 1G A/C condenser.
    · 3 211
    It looks like partsgeek has them.
  • pottersgst replied to the thread What did you do to your DSM today?.
    · 11,796 718,700
    Have checked it with mechanical at home at idle, 10psi as normal, but aems simple, looks good, simple to install and ive never had bad experience with them. Plus they look decent and i appreciate the numbers over trying to glance where a needle...
  • Colin rosti posted the thread 2G Clutch dragging in Drivetrain Tech.
    I currently have a clutch dragging issue, it grinds in all gears trying to put it in. It happened once slightly for a few seconds and then a day later fully immobilized my car.I have so far replaced slave cylinder and bled multiple times. Does...
  • jdxnc replied to the thread So what are you working on that’s NOT your DSM?.
    · 1,663 121,057
    Little more progress on my scales, just waiting on the last batch of load cells to arrive now.You must be registered to see element.
  • Drewpy Dawg replied to the thread What did you do to your DSM today?.
    · 11,796 718,700
    I rebuilt my NT throttle body with new seals, polished throttle plate, re-plated parts, etc. Then I installed it on my motor and realized I forgot to peen the screws in the throttle shaft. So now I have to order a new gasket then take it off to...
  • jdxnc replied to the thread What did you do to your DSM today?.
    · 11,796 718,700
    Did some CAD(cardboard aided design) for my new catch pan.You must be registered to see element.
  • 92AWDHX40 replied to the thread What did you do to your DSM today?.
    · 11,796 718,700
    More wiring the haltech next ic7 wiring.
  • explicitgst replied to the thread 2G Low Oil pressure.
    · 25 1,420
    I've used amayama a bunch in the past. Love them. No shock duties when the packages arrive. Recently got crossmemeber bolts and collars that are unobtainium, unless you use Amayama.I'll probably get that, front and rear main seals, freeze...
  • Drewpy Dawg replied to the thread 2G Low Oil pressure.
    · 25 1,420
    I just received an Amayama order today. I ordered $120 worth of parts. After shipping and duties it was $200. But some of those parts aren't available in the US, and a couple of them were far cheaper than the ones that are in the US, so it ended...
  • We're on Boost replied to the thread 2G Low Oil pressure.
    · 25 1,420
    Bummer!Going to build a 6-bolt then? Check this out, this is what a dry-run through Amayama check-out looks like right now, today. Did this with a You must be registered to see element.You must be registered to see element.Then, the...
    • 1990 type OFH from Amayama - in shopping cart May 18 2026 - address blanked out.jpg
  • AtomicSK posted the thread 91 Laser in DSM Build Journals.
    This is the Build Thread for You must be registered to see element.. Reply below.
