zero compression on all 4??
93blacktsi
73
Mar 2, 2009
chambersbrug, Pennsylvania
ok long story short.head blew replaced it with a head that was just back from the shop.i had to put my valves and stuff it in.got it on the car and it wouldnt start.check the compersion it was zero all the way across.what can cause this?im stumped at this point
resloved valves did not seat
because you can see the gap between the head and valve.the just came back from the machine shop it had bronze guides, new seals and was resurfaced.
ran in to a problem.i dont a valve spring compressor, i was able to get them out but have no way to get them back in.anyone around chamberbrug pa have one i can use ?
Try Autozone and see if they have a spring compressor for your purposes. Usually you leave a deposit and when you return the tool they give the deposit back...
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
