Your thoughts on my logged run B28 @ 20psi & HKS 264/272 cams
Generation X
504
6
Aug 12, 2003
Asheville, North Carolina
1. RPM 2640 TIMING 33
2. RPM 2684 TIMING 33
3. RPM 2740 TIMING 29
4. RPM 2804 TIMING 29
5. RPM 2884 TIMING 25
6. RPM 2992 TIMING 23
7. RPM 3112 TIMING 23
8. RPM 3252 TIMING 20
9. RPM 3404 TIMING 19
10. RPM 3560 TIMING 16
11. RPM 3748 TIMING 14
12. RPM 3928 TIMING 13
13. RPM 4120 TIMING 12
14. RPM 4352 TIMING 10
15. RPM 4544 TIMING 9
16. RPM 4756 TIMING 9
17. RPM 4972 TIMING 9
18. RPM 5200 TIMING 9
19. RPM 5368 TIMING 10
20. RPM 5612 TIMING 12
21. RPM 5800 TIMING 13
22. RPM 5960 TIMING 16
23. RPM 6152 TIMING 16
24. RPM 6304 TIMING 17
25. RPM 6452 TIMING 17
26. RPM 6596 TIMING 17
27. RPM 6724 TIMING 17
28. RPM 6832 TIMING 17
29. RPM 6956 TIMING 18
30. RPM 7044 TIMING 8
I let off at 7044 RPM. Temp outside was about 82 degrees. I didn't bother with logging o2's. I think I need to add some fuel from 4000 RPM to about 6000 RPM. What do you guys think? I wasn't spraying nitrous on that run either. Thanks for any advice! :)
CanadianTSi said:
Looks like your spooling super late, did you punch it at 2500?
Well.... I tried my best to. I was kinda thinking the same thing. I'm gonna try another run again tomorrow and see for sure. Surely my cams wouldn't be causing such a late spool would they? I mean since they more or less moved my power band up a little. Thanks for any advice.
Ok fellas I'm finally back now that it's been a week later, sorry about that. :( My first run was actually at 18 psi and falling to 17 psi by redline, and "Not" 20 psi like I had previously stated in the thread. Sorry for the mis-info, I thought I was running 20 psi but that wasn't the case. Anyways... I went and did another run friday night running the same boost, which was 18 psi. I'm having a problem with my logger registering o2's for some reason and It's pissing me off! So here is how the run went. I'm also noticing that I'm getting a little bit of a high end mis-fire, or hesitation problem up top as well. Let me know what you guys think. Thanks for any advice! :)
1. RPMS 2540 TIMING 27 AIR FLOW 4.29
2. RPMS 2628 TIMING 25 AIR FLOW 4.94
3. RPMS 2772 TIMING 24 AIR FLOW 5.59
4. RPMS 2908 TIMING 23 AIR FLOW 6.39
5. RPMS 3068 TIMING 22 AIR FLOW 7.10
6. RPMS 3236 TIMING 20 AIR FLOW 8.21
7. RPMS 3424 TIMING 17 AIR FLOW 9.57
8. RPMS 3624 TIMING 15 AIR FLOW 11.22
9. RPMS 3840 TIMING 12 AIR FLOW 13.19
10. RPMS 4064 TIMING 11 AIR FLOW 15.46
11. RPMS 4308 TIMING 10 AIR FLOW 17.23
12. RPMS 4536 TIMING 11 AIR FLOW 18.73
13. RPMS 4792 TIMING 11 AIR FLOW 20.69
14. RPMS 5064 TIMING 11 AIR FLOW 22.10
15. RPMS 5280 TIMING 13 AIR FLOW 22.71
16. RPMS 5532 TIMING 15 AIR FLOW 23.22
17. RPMS 5748 TIMING 16 AIR FLOW 23.51
18. RPMS 5944 TIMING 17 AIR FLOW 23.83
19. RPMS 6192 TIMING 18 AIR FLOW 23.89
20. RPMS 6368 TIMING 19 AIR FLOW 24.58
21. RPMS 6528 TIMING 19 AIR FLOW 24.34
22. RPMS 6700 TIMING 20 AIR FLOW 24.50
23. RPMS 6880 TIMING 20 AIR FLOW 23.85
24. RPMS 7032 TIMING 20 AIR FLOW 24.61
25. RPMS 7096 TIMING 20 AIR FLOW 24.80
26. RPMS 7244 TIMING 20 AIR FLOW 23.15
CanadianTSi said:
Looks good to me, I would tune it to 20psi.
Yeah thanks, that's what I was thinking. I also forgot to mention that I have bumped up my base fuel pressure to around 47 psi. I think I'm going to try and do a log at the same boost setting while spraying the 75 shot the next time, and see what happens then. I will keep you guys posted on my log. Thanks!
