Your Opinion
SiNiST3R
347
May 10, 2004
NorCal, California
Well i've been thinkin on what to set my tunning at and trims at if ya could help me with some if that would be alsome.
I moslty use the car to and from work not far at all and if there is anything to race i give it a short go, and every so often race on the weekends.
With this in mind here is a list of my mods two main things am trying to get are;
A nice Psi Setting, and my trims on my AFC HP and LP.
I know the MAJOR item i am lacking is the FPR witch i may have in a month or two as of now everything works nice.
List of Mods for Eginewise are as follows;
INTAKE Ingen Intake tube
Evo III Big 16G
LUCAS 550CC Injectors
S-AFC II
1g BOV
Walbro 255 FuelPump
Apexi 3" N1 Exhaust (Cat-Back)
MBC - Homedepo Style
STOCK ;
FPR - (Will have in about 1-2 months)
SMIC - (Trying to find one under $500 with piping and everything)
Thanks guys!
kpt4321 said:
Use the SAFC tuning guide in the tech articles section. Start by setting the boost around 16 psi.
Ditto, and you'll need to get some tuning tools like mentioned in the tuning guide. A pocketlogger will be able to tune low throttle using ecu fuel trims, and high/wot throttle using timing and o2 voltages. A wideband would also be great for better tuning on the wot runs.
know of a good link where to buy a cheep but working logger ie cheep PDA that will work? what model should i look for on ebay?
If you're going with pocketlogger software, then any palm unit running OS 3.0 or higher should be fine. Palm III's are pretty cheap on ebay. A lot of people are using the newer cheap M100. There are several threads about what palms to use for the software.
