Yet Another 6 Bolt Swap No Start Go Figure
jimbob_843
587
5
Mar 11, 2010
Dorchester, South Carolina
Alright so my setup is a 95 gst with 6 bolt swap. 95 ecu no tuning stock everything other than 16g turbo and exhaust. 1g cas rewired the RRE version 2 way. RRE Instructions
Now everything was running fine upon 1st startup. Had a tapping noise from a slightly bent valve (discovered afterwards) but other than that nothing was wrong. Did a couple break in pulls and what not, then just started to cruise around. Next day was cruising for about 30 min or so and next thing i know the car dies out and i hear a loud backfire. First initial thought was oh great heres that 6 bolt swap misfire..but no. Let it sit to reset ecu swapped another cas (junkyard) and still nothing. Just turns over no start.
I have new valves they are lapped and seal perfect.
Fuel is getting to rail and into cylinders.
I have spark
ECU is good no signs of shorts.
I have no idea what is going on here guys. Things in question are thermo sensor? Knock sensor? injector firing order? Bad CAS??
Tommorow i am gonna get some starter fluid to spray to see if she fires up a lil. Feel like a noob all over again:confused:
Oh and mechanical timing is spot on.
I noticed that you have replaced the coils but did you ever replace the Power Transistor or the coil wires?
Whats the condition of the injector resistor pack? I had one crap out on me a while back and it caused all sorts of spark issues, swapped it and problem solved. Also inspect your MAF for any damage or try swapping it out, something may have gone screwy internally.
  • For sale 2g 2G Mishimoto Radiator
    2G Mishimoto Radiator $175 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 4G63 Valve Cover ( No broken bolt holes or cracks )
    Valve Cover ( No broken bolt holes or cracks )* great candidate for powder coat or paint *...
  • For sale 2g 2GB Manul/Turbo Engine Harness
    2GB Manual/Turbo Engine Harness $150 + shipping & paypal fees* wired for 1G CAS, CAS Included...
  • For sale FIC 1650 High Z Injectors
    I have a set of FIC High Z 1650 injectors. They are in great shape with only 500 miles on them...
    • jking29
  • For sale 2g Misc parts
    Have a few things for sale. Open to offers, located in Toronto Canada but can ship- S90...
    • Bedicine
