xtd flywheel review
suprasalas
75
Aug 10, 2011
Yuma, Arizona
Hey you guys i just bought a xtd flywheel from ebay. Ive been doing some reseach and there is no review on this flywheel.. ima put my on this week ill post up the goods and bads on this flywheel.. im praying it holds up:pray:
Worked great for me when I had it. Its just the flywheel...its harder to screw up than the clutch is...and even the XTD clutch held great for me on an E316g that was track raped
hell my comp would run you cheaper than that and proven to take anything to put against it.
my personal experience with xtd is that its garbage and their costumer service is half ass. theres things you can buy off ebay and things you should know better IMO. but its gana take more than just a week to tell us if its any good.
i wish you the best of luck with that part and hope you had better experience than i.:thumb:
well the flywheel is holding up pretty good no problemes what so yet.. i got to say my rmps rev up faster since its lighter then the oem one.. ill keep updating if something where to go wrong.
this is the xtd..
How did this turn out for you? I'm looking at a lot of different Flywheels and i need to make a decision here in the next day or two. I've been told not to go with the Fidanza as this is 100% a daily driver and i won't be doing anything to it, so it will stay stock until i find another shell. I just want something that is going to be good enough for a daily that will hold up a little abuse that i throw at it every once in a while ;)
Well to be honest if it’s a daily I would stick to the oem, I only bought the xtd flywheel because I was on a tight budget. Overall the flywheel held up the weekend beatings, but totally different story with the xtd clutch. The xtd clutch gave out on me around 4000 miles:banghead: even when I gave it 1000 miles break in period. One thing I notice was that the flywheel flexed each time I pressed on the clutch due to the fact of the 13 holes around the center, I assume they made them to remove weight from the flywheel but in fact they actually weaken the structure of it.
