WTH happened?
turbo90gsx
654
3
Feb 12, 2004
Fort Wayne, Indiana
Ok, my valve cover gasket was leaking really bad, so I decided to replace it. I got the gasket replaced with no leaks, but then I drove it around for a little, and it started to idle surge*never used to happen*. Then I got on it a couple of times, only to hit a fuel cut*never used to happen*. What the hell could have posibly happened? BTW, I have a 255lph pump, running 16.5lbs of boost.
you probably missed a vacuum line somewhere - do an intake leak test if the problem is not obvious
boost leak ack!
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
