na_turbotalon
- 180
- 0
- Jan 27, 2005
Edmonton,
I was driving my car home yesterday and passed someone, when I hit full boost (16psi) I heard what sounded kind of like a large release of air. There is alot of smoke coming from the exhaust pipe now, and the car won't boost, the turbo spools just as fast as before but stops at 0 psi. The smoke from the exhaust isn't black or white, just grey and doesn't smell out of the ordinary. I've done a compression check and its 175 across, replaced my vaccum lines, all new T-bolt clamps, and I've been going through the EMS trying to find something out of whack.
My friend lent my boost leak tester to someone else and I'm waiting to get it back right now, hopefully that's the problem. But I've only owned this car for 5 days, and it's my first experience with a MAFless DSM, so I'm unsure how differently it would act with a boost leak. It smokes alot and burns alot of fuel, but it also smokes the most at idle. If anyone else with a speed density car has any experience with this please enlighten me.
This isn't the car in my profile, it's mods are:
- JDM 6-Bolt
- HKS 272/272
- HKS Cam Gear
- HKS Valve Springs
- Ross Pistons (9.0:1) .020 over
- Eagle Rods
- Balance Shaft Removed
- Cometic Headgasket
- ARP Head and Main Studs
- Energy Suspensions Motor Mount Inserts
- Garrett T3/T04E 50-Trim
- Coated 2G Exhaust Manifold w/External Wastegate Neck
- TiAL 46mm Wastegate
- TiAL 50mm Blow-Off Valve
- BIG Bar and Plate Front Mount Intercooler
- 785cc Injectors
- Walbro 255lph Intank
- BJ's Sheet Metal Intake Manifold
- Mustang 75mm Throttle Body
- Mustang IAC Valve
- 3" Intake Pipe with K&N Filter.
- 3" Stainless Steel Downpipe
- 3" High-Flow Cat
- Mechanical Boost Activated Dump System
- Stock Cat-Back Exhaust!!!
- JDM 6-Bolt
- HKS 272/272
- HKS Cam Gear
- HKS Valve Springs
- Eagle Rods
- 785cc Injectors
- Mustang IAC Valve
- 3" High-Flow Cat
