Ryan95tsiAWD
- 262
- 6
- Apr 22, 2002
Goose Creek,
South Carolina
So I was driving along at 45mph or so and hit a recessed railroad track. The car didn't cut off or do anything crazy but the next time I went WOT the car felt like it was pulling timing like crazy after about 10lbs. First off, I have dmslink, and all supporting mods (fmic, 650s, 255fp/rewire, etc.) with an e16g. I have not done a capture to see exactly what it is as my laptop is dead right now. I have my CEL set for knock at a very low count and have not seen it come on yet. I did a boost leak test and did find a couple of lines that were off. One that went to the fuel rail and the other connects to some valve below the TB. Sorry, I really havnt worked on DMSs in a few years so i forget what it is called. Anyway, after I put those back on, 20lbs+ air would stay in for a long time. I was testing from before the turbo. I would have thought it would be a boost leak as that is what it feels like. Next step, gapped and install new bpr6es plugs but it still does it. I have pushed it a little even after the car goes to crap and it still builds boost. At this point i am out of ideas. Anyone know what i could have "bumped" that would cause this?? Thanks.
EDIT: If this makes any sense, It feels like the car is hitting a rev limiter as soon as there is enough load on the motor to cause the issue. It Doesn't matter what RPM i am at. I can take the car up to redline at half throttle and minimal boost (5lbs or less), although I think that would still be in open loop mode(please correct me if I am wrong).
