Smokin80
- 239
- 117
- May 2, 2006
SOOOOOOOOOOOOOOOOOO funny story. (These are manley pistons i am talking about just so you know)
Due to a shipping error when i built my head i didnt get to put my ti retainers on and since i didnt know how long it was going to be till i got new ones i built it anyway. NOW i am putting the ti retainers on and instead of screwing around with doing the springs with the head on i just pulled it. SUCKS cause the motor is bran new. But such is life.
I pull the head off and there on the pistons i see little marks from valve contact on the intake side. Before you ask i am 100% positve the motor was timed correctly and there is no way the motor was ever turned over with the cams installed and no timing belt. So i start looking at the pistons and notice that the exhaust side valve reliefs are closer to the cylinder wall than the intake side...it is not a substantial difference but you can tell if you look very closely
Shouldnt that be the other way around? If they were i dont think the marks would be in the pistons. There are no signs of contact on the valves by the way. The arrow that says front of engine is still on the pistons and it points to the front of the engine(timing side....RIGHT????)
Is it possible that there is an error with the pistons and they were labled wrong or is there something i am missing here? I dont want to go installing 280 cams that open for longer and lift higher when im apparently already having piston to valve contact.
SO CONFUSED/PISSED
Help me out guys!!!
Thanks
Garrett
Shouldnt that be the other way around? If they were i dont think the marks would be in the pistons. There are no signs of contact on the valves by the way. The arrow that says front of engine is still on the pistons and it points to the front of the engine(timing side....RIGHT????) Is it possible that there is an error with the pistons and they were labled wrong or is there something i am missing here? I dont want to go installing 280 cams that open for longer and lift higher when im apparently already having piston to valve contact.
SO CONFUSED/PISSED
Help me out guys!!!
Thanks
Garrett
