ApexVIII
- 812
- 5
- Jan 12, 2008
Modesto,
California
so i can not stand the gray interior, so i am trying to wrap as much as i can in Black "leather look" Vinyl. i will try to turn this in to a write up,
... so stay tuned.... i will add more pictures
if there already is a write up can some one let me know i wanna check it out
Thanks
Derek
Edit: here are a few pictures, ill try to get some better ones tomorrow or so....
I sanded the plastic so the adhesive would stick better. i used 80 grit sand paper
Its a lot easier to get it to fit wit out wrinkling if you start from what would be the front of the car and work back towards the speaker.
i had a hard time getting the part where the water bags are to stick down with out holding them, so i got some larg ziplock bags, filled them with water and let them set
Sanding the speaker grill to paint black
I used hot glue to hold down the edges, it works alot better then the glue it drys alot faster. so get a high heat glue gun for this part
Thanks
Derek
, but it has a gray carpet dash cover thing that i might dye to black.
