Wow, rear motor mount, what a ...
turbolarry
730
4
May 2, 2004
Corona, California
I got the energy suspension motor mount inserts. The front, easy, no sweat, done. The rear wholy f@#$ s!@#! I can't figure out a way to get it out. I don't want to drop the tranny, or remove the fuel filter, that's a lot of work in it's self. Does any one have any tips, pearls of wisdom, anything? Battery tray is out, move the shifter cables? Quit being a cheap skate and fork over cash? Any advise would be greatly appreciated
Put your car on jackstands, then support the engine/tranny with a block of wood and a jack. pull the bolt out of the center of the motormount, jack up the engine til you can pop the inserts in and lower it back down until you can jam the bolt back in. If that doesn't work, unbolt the mount from the tranny and move it until you can get the inserts pushed into the sides.
