darknezz7
- 571
- 83
- Mar 30, 2014
Eugene,
Oregon
This will probably get deleted quick but oh well, not sure where to put it that people will see. Maybe this will save someone else from getting screwed.
First our brand new crapbay turbo had a cracked CHRA, getting refunded but what a hassle, never again crapbay!
So a member here has this posted in for sale:
http://www.dsmtuners.com/threads/mitsubishi-evo-3-16g-like-new.495921/
"like new real Mitsubishi evo 3 16g with low miles under 4500 miles never boosted over 12psi. No shaft play, no broken or striped bolts, no oil or coolant lines. Comes with wast gate turbo is ready to bolt on and go. Reason for selling is because i am parting out the car."
Sounds great, I offered him $300 and he accepted.
What I got in the mail was a small ripped up package with pieces of the turbo hanging out, no packaging at all.
What was in the package was a dirty old rusty worn out turbo with a lot of shaft play.
The wastegate flapper has been poorly welded on and sticks open, the actuator was not even big enough hole to go onto the flapper linkage. I drilled out the hole and put some washers between the turbo and actuator so that the flapper didn't open to far and stick open... Think that will be ok?
I checked the numbers (should have first from the picture in ad) what I got is a real evo 3 big turbo, what he had pictured however is a small 16g, I would have stayed away at that point if I did that first. Not only that he mentions he is parting the car, but in text he said he upgraded his car.
And finally his paypal is "auto recyclers". I believe he is advertising good turbos then selling junk from the wrecking yard.
Anyway we our tied up $600 now in crap turbos and really want to drive the car. Thinking keep the boost at 14 and dont go over 5000 rpm and this turbo will last a few months hopefully....
What do you guys think? I see the evo 3's going for 450 used, so 300 still might not be too bad, but its the fact that it is worn out and he said it was like new.
pics of said "like new" turbo... This was AFTER we cleaned it, was covered in oil and rust...
Thinking run it for awhile, then upgrade to a hx35 and sell this thing to someone else, but I will be honest.
I hope the owner at least has enough common sense to put the car on hold until a replacement can be found.
