would this fit a supra SMIC?
You can use the upper s pipe without modding it, for the supra smic you need to cut whatever bov pipe you have to make it fit (shorten it) and because of the angle on the licp on the supra you could use that lower pipe but might have to shorten that too becaus the supra inlet and outlet sit further to the right than the stocker does. You know you could use your stock lower pipe and mod it at the end to match up with supra smic. I used a 2.5 45* elbo off the supra simc and a 2.5 - 2.0 exhaust pipe to match it to my stock lower pipe. The upper I cut my dejon upper pipe in the middle and shorten it 1" and used a 45* 2.5 hose on the ssmic outlet then took a piece of stock intercooler hose and put it the end of the dejon pipe to make up for the 1/4 inch difference. Did a boost leak test after that at 23 psi and no leaks.
