Would these rims fit?
someguy1984
31
Jan 21, 2009
Tampa, Florida
Here are some things to try...
1. Put them on, turn your wheels both ways, and rotate them to look for rubbing and brake/suspension clearance. It's not that hard...
2. Find out the bolt spacing and offset from the guy you bought them from, or...
3. Take them to a wheel shop and have them tell you...
your bolt pattern is a 5X114.3 so if thats what they are then your in the clear. and trust me lots of cars run this pattern.
-jeremy
i did some research and what i see is the tsx runs the same pattern so your good to go. and i think they look pretty:)
I don't know anything about that, which is why i'm asking...I can ask the guy.
From my research, the only width these come in is 7.5", for the 18" The recommended offset for the Tsx is 42-50mm. A lot of 18x7.5 wheels are 42-45mm offset. So, I say these wheels are in that range. They should fit fine but, like mentioned above, it's best to test fit on the front and rear. I'm not sure about the price. It's really about what you are willing to pay.
Definitely ask the seller what the offset is to make sure. And while that is a beautiful car, be different, dont strive to look just like someone else's car.
Well, not striving, but in general i want my car similar with my own perks.
I would test it out with him, but he is 4 hours away...Which is why I'm on the forum doing research. I don't want to drive all the way there and not have it fit, you know?
So, if i ask him what the offset is, what do i need to hear? What is good, or bad?
Okay. The recommended offset range for an Eclipse GST is between 35-45mm. As long as the offset falls within that range, you'll be okay. That tire will fit but, the recommended size is 225/40-18. That's about as close as you can get to the stock tire diameter. The 35 series tire will look a little small on the Eclipse as it is slightly smaller than the stock 16" tire. I hope that helps.
  • For sale 2g 99 2G parts
  • For sale 1991 Mitsubishi GTO
    1991 Mitsubishi GTO JDM Import
    • jesuschr
    • ist dwa
