would i be around 300whp?
Status
Not open for further replies.
NismoDSM
32
3
Jul 7, 2013
Aberdeen Proving Ground, Maryland
I have some things waiting to be installed and im wondering if my setup once tuned will be able to support 300whp.
PTE 880cc injectors
Wally 190LPH
Evo3 16g w/8cm fp housing
PR FMIC kit
Extreme psi Intake tube/filter
Ported Evo3 mani
full 3" turbo back exhaust
EcuFlash/ceddymods tuning
PR radiator
Southbend "stage2" street clutch.
Im looking to be right around 300whp/tq so i dont burn my new clutch out too fast then upping the boost when i replace it. any ideas on boost levels recommended for 300ish? and should that fuel setup support 18-19psi?
I see no reason why you wouldn't be able to reach 300whp, fuel setup is fine (assuming pump gas). I'd say around 20+ psi will get you there...
The setup you listed should get you to your 300hp goal. If you haven't done so already, I would highly recommend getting a wideband. I do not have much experience with the wally 190, but from what I have read, it should be enough pump for you to reach your goal. 880's will do assuming you are going to be running pump gas. If you plan on running e85, you could get close to maxing them out. Other than that, reaching your goal shouldn't be a problem.
Turn up the boost and you will see 300whp but not with 18-19psi.
My buddy's link estimate was 320hp on a s16g running 17psi.. I wouldn't get all hyped up on cranking up the boost until you get a wideband.
Status
  • Wanted 6 bolt NT water pipe
    • chrisman287
