would a turbo ecu work on a non turbo car
Azn Wndr
Apr 9, 2009
Topeka, Kansas
I dont have access to a n/t ecu right now and I'm just wanting to see if the ecu is the source, I dont plan on driving it just want to see if the ecu is the issue
Thats going to be a no... There are several differences between the pair. If you do a quick search you can pull several threads on the topic.. I might be mistaken but you have to change a few things to use the turbo ecu. I have personally never tried it so I cant be of much help in that area. Are you using 450cc injectors?
No you can not use it. Our ecu also has a knock sensor wire and an additional wire for the Karmen Vortex. Our stock ecu's are sending a signal for a 450cc injector. It would severely over run your injectors capacity. There are probably several things I don't even know about that wont interchange. When posting in the future please take a few moments to correct any typographical or grammatical errors. Try Searching using the fabulous tools provided by the fine people here at dsmtuners. Admin goes a great job of keeping any topic just a few key strokes away. :thumb:
