ECMlink WOT Sputter
I just finished downloading the newest software and got your 2 newest files downloaded into the ecu and corey i must say man each time i do a 3rd gear pull its getting faster and faster your doing a great job man! Also i did a cold start idle and cruise log along with a 3rd gear pull. Tell me what you think?
Hey guys i added a little more boost and switched out my boost controller with a good one now my boost is under controll a bit better now. Heres 2 of the newest logs now with boost set at 25psi.
first log was with my 2 step dam thing launch so hard!! flowing 45lbs :)
second log was a 3rd gear pull along with a little big of cruise.
Tell me what you guys think about these logs please!
We're kind of doing the ass-backwards since I know your closed loop fuel trims are garbage but, while you're doing WOT pulls, we'll get you going fast first I suppose.
Advanced timing a bit during spool up and retarded it at peak boost and a few degrees where you upset the knock sensor a little. Also tweaked the VE map so your WB better line up perfectly next time you mash the gas.
---> You're maxed running Link v3 lite on 26psi. Read the product comparison page, v3 is good to 10k RPM and 40psi and v3 lite is good to 8k and 26psi. Wiki: Product Comparison
:dsm:
Asome corey ill upload those tunes into the ecu tomorrow and get back with you to let you know how she does! Looks like i might be takein her out to the track this weekend to see what kind of slips she will run :)
That sucks that were pretty much maxed out right now :( Looks like ill have to upgrade to the full version now!!
