Worth to get coolingmist contoller? How long does 2.0 quart tank last?
dragrush
187
May 1, 2004
North, Louisiana
I am getting water/alcohol injection kit from coolingmist.com but I am unsure which kit to get. My goals are to get between 400-500 on 93 pump with one of these kits and dsmlink (other mods in profile) I plan on just running low boost on just 93 pump and turn on water/alcohol injection at high boost. Will a kit with a contoller be neccessary like this one http://www.coolingmist.com/pagedisplay.aspx?feature_key=controller or will one of the standard kits be just fine like this one http://www.coolingmist.com/detailmain.aspx?pid=01250TBF? There also is a kit with a 100psi pump and for a $100 more a 150psi pump, which one is recommended? And on average how long does a 2 quart tank last?
http://www.coolingmist.com/faqs.aspx?fcat=1
Question:
How long will my tank last?
Answer:
A 1 gallon tank will typically last between fuel fillups for most gasoline engines. A 2 quart tank would last typically 7-9 runs at the drag strip and some driving around town. If you dont have a super heavy foot the 2 quart tank will last a while. If you have a diesel and are towing we recommend the 6 gallon tank.
All found on the site's FAQ.
