robertseber
- 74
- 2
- Mar 28, 2010
cookeville,
Tennessee
I have a 97 gst that the tranny wouldn't go into first gear and was kinda weird going in reverse so I swapped transmission flywheel pressure plate shifter base and shifter cables and still have the same problem.
It will go into first smoothly as in all other gears but when u let out on the clutch it will grind and throw it in neutral.
Ive adjusted the clutch pedal from one extreme to the other the slave cylinder is moving plenty and has roughly 5,000 miles on new slave and rebuilt master cylinder.
All other gears work perfect other then 1st and it will not go at all. Ive disassembled the 1st transmission and don't see any damage to the 1st gear hub or synchros or gear or fork.
