GSXspeeddemon
- 88
- 0
- Sep 20, 2005
Austin,
Texas
Car is a 95 GSX with dsmlink but its not working since it looks like the ecu is not getting power.
I just finished a 6bolt swap and tried to start the car and nothing. The CEL light does not come on when you turn the key. I removed and opened the ECU and it looks fine no leakage and no burn marks. I have been reading about the MPI relay however have not figured out how to test it. I saw the write up for the 1g relay but not the one for the 2g 95 one. I have checked all the fuses and they look to be in good condition. \
I am a noob at the electrical stuff but I was using a cheap multimeter (not digital, has a needle) and tested to see if the CAS was getting any power and the needle would flicker. I tried the same thing on pins 25 and 12 on the ecu harness (ecu was unplugged) and go nothing am i supposed to have the ecu plugged in to test the the power to it?
Any ideas or help would be greatly appreciated!
