6bolt swap car wont start :( HELP
l3igl3ang
539
Aug 10, 2005
ft smith, Arkansas
Ok we did a 6bolt swap we did everything just as the guides say got all the plugs hooked in rewired the 1g CAS and stuff and when i turn the key over nothing besides a fuel pump and some other sound so we then said hmm the staters not working right which we forgot to plug in the relay so we found a plug that was not pluged in at the fron of the car which matched it perfect so we hook the hot to the battery and the ground and then we ground the other wire and try and just see if it spins bet hell no nothing happens :mad: and i know the starters are good we have 2 of them so what could it be not letting it work? relay maybe went bad somehow?
You are just too vague in your descriptions man... :sosad: I mean what does the car do when you try to start it. what is it doing? What is it not doing?
Is your battery charged up? Are you stepping on the clutch.. I don't know...:)
its eather the neutral safety switch or i have the wrong plug on hooked in my starter begin that theres 3plugs that match the same one as the starters.
btw where would the neutral safety switch be located?
it plugs into the transmission right? if so then its hooked up
im thinking i got the wrong relay hooked to the starter cause the one i used wont even reach to the back of the motor and i think i hooked the one that gose to the starter to my VAC line plug
I am not fallowing a thing your saying. I think your confused betwene a relay and a femal spade connector.
Relays are 1X1X1 inch cube shaped and a spade is about 1/2X1/8X1/8 inch.
Check which one will light your test light when you turn the key to the on position.
I figerd it out somehow my neutral safety switch magicley came unpluged LOL must had unpluged when pulling on the wires so i hooked it back it and it spin away :)
well you think you guys can help me out? I did the swap wired everything rite and my car won't start. The battery is good i have power but when I crank the engine I only get power to one coil pack. The coil is not the problem because I've tried it with two different coil packs and does the same thing. I've also used two different CAS and still nothing!?!? Any suggestions???
