1G Won't shut off
wilquin
4
Apr 5, 2023
Port Richey, Florida
My 90 Talon won't shut off when turn key to Can remove the key. And it's still running.
Does it turn itself off after 5 minutes or less?
Edit: nevermind, was thinking hidden turbo timer, but I remembered you have a NT.
Does it have some kind of aftermarket alarm system or anything else that could be wired into the ignition switch circuit?
No no after. Market items on the vehicles I did overnight. A Ignition switch I will be putting it in today once it gets in. I will reply if this will get the trip done
I got the new Ignition switch put it in and I still have the same problem. I follow through my wire harness and come to find out. There was a wire that came loose or disconnected under the driver's seat reconnected now. Everything is up and running thank you for the help.
