Wont run right
EVTBernie
85
May 4, 2006
South Burlingto, Vermont
So after a while I finally got the car running but I'm hearing a hissing noise which sounds like its coming from one of the injectors. I'm guessing I'm leaking air someplace. Car wont stay running, when you rev it it bogs bad. Also when I keep the throttle pushed at 3-5 rpms and hold it will run but then bog back down. I just put 550cc and 2gmaf. When I came in my clothes smelled bad like rich car smell. I'm guessing if I am leaking air the extra fuel is compensating therefore making it run really rich
****Just took injector 1 out and the bottom rubber was gone. Hence the hissing and problem****
I would do a boost leak test to ensure you do not have any leaks any where else.
  • Wanted 6 bolt NT water pipe
    • chrisman287
