shaneyeend
- 241
- 0
- Nov 26, 2003
laramie,
Wyoming
It is the weirdest thing, it randomly desides it doesn't want to idel, it wont ever die but it will go from its normal 900rpm down to maybe 100 and then jump up to 1500 then settle to 900 for maybe a second then drop again, I thought it was a tps so i replaced it and still had the problem.
. So you probably wouldn't know if the engine was throwing a new code. Go have it scanned at auto zone and tell us what it says. With your setup and the time you have had it I'm going to bet your o2 sensor is about to take a dump on you. They usually are very random. Otherwise, it could definately be an IAC or the TPS like previously mentioned.
