Wont go into First Gear/Timing Belt problem
andrew4g63
47
Nov 15, 2005
LG, Wisconsin
Just got done with rebuild and start car try to drive and wont go all the way into first.
Goes in all other gears and it dorve fine before rebuild. I put a new SBR clutch in and a
extended rod slave rod. It is also a 90 trany in a 92 car but it was fine before. Any ideas
Also my timing belt seems like its loose in one spot when the car is shut off. It doesnt matter what postition the belt is in the same spot is always loose. Just wondering if this is a problem.
Trany problem was shifter cables needed to be 1990
and im still wondering about the t-belt being loose
