- 466
- 1
- Mar 26, 2004
Spokane,
Washington
My car will not run with the MAS plugged in. I have replaced the MAS with a known good unit, as well as the ECU. Car idles fine without MAS, and drives fine except will not boost. I do not know where to start with this - it was working fine before I did a head gasket job on it. I do not think I missed any sensors - can someone throw some ideas out there?
Car is a 1991 Eclipse GSX
1gnt head with turbo cams
OEM HG
'93 eprom ECU.
Most recent underhood pics for troubleshooting can be seen here:
http://www.hdesk.org/eclipse/pictures/6-27-06/
I am at a loss here. Car runs fine other than under boost. Already boostleak checked - it makes a bubbling sound like when you blow air into a straw which is in a cup with water in it. Timing is on.
OEM HG
'93 eprom ECU.
