Wiring schematics needed! ISC harness/clilp missing!
dsmmaniac12787
156
May 17, 2008
Prince George, Virginia
Hey everybody, I have a 95 gst with a galant vr4 6 bolt. My idle is ridiculously erratic and surges at times as well. I thought I just needed to replace tps and mess with throttle cables. Maybe clean up intake and check for boost leaks. I was looking at it and there is NO IDLE SPEED CONTOL SENSOR! I got one and screwed it into the TB then looked for the clip and could not find one anywhere. So I guess what I need is the schematics of that area so I know where to trace it back or where to splice to make a new one. If anybody can help I would appreciate it. THANKS!
There is a torrent up on piratebay.org , search "DSM" and you'll find it. It's the 1G/2G factory manual back up CD.
This site is redirecting traffic to ebay.
That sensor is not the ISC. That is a sensor used only on 1g's - you have it since you have a 1g throttle body. You will not plug that into anything on the harness.
Leave it in the throttle body - it prevents the throttle plate from completely closing and getting stuck. But no, it will not connect to any wires from the harness.
