wiring problem 99 gsx
ssmokeyy
Jun 5, 2009
spokane, Washington
Hey guys im building a 992 gsx spec but have changed everything about the car. It now has a 1gcrack 2.3 stroker 2g head. Kinda have 2 things to ask. First i will be buying a 97 ecu to run ecmlink. Will i have to change the injector wires and spark plug wires at the same time or can link take care of this problem? Also looking at using spark tech cop system and was wondering witch way i should wire it up.
The 95 ecu is what you need.
I have tried flipping wires, injector phase, and inverting in code but the best results i have had was running the 95 cas.
You could run the cop in wasted spark but that will down grade the ignition system. The ecu needs to have 4 channels and adjustable dwell to run cop correctly.
