92 gsx wiring problem
Does anyone know anything about rewiring the oem engine harness I want to trim as much as possible. What sensors do I have to keep please help.
For the ECU harness this are your options you can delete.
Auto-Cruise (Cruise Control)
Manifold Differential Pressure MDP sensor (keep this for aftermarket MAP)
Brake Fluid Level Switch
Fuel Pressure Solenoid (FPS) Valve
Exhaust Gas Recirculation (EGR)
Turbocharger WasteGate Solenoid Valve Boost Control Solenoid (BCS)
EVAP Emission Purge Control Solenoid Valve
Air Conditioning (A/C) Compressor
Fuel Pump Check Connector
Timing Check Connector
Tachometer Signal Connector (Delete But keep wires)
Rear 02 (keep white wire pin 75 for Wideband)
Hope it helps, do you also need info on the Fusebox and chassis harness?
headlight pop ups (if you don't want them)
Dual Pressure Switch (AC)
Hood Switch
dummy light
Oil pressure stock gauge (use aftermarket)
Left Fog Light
Right Fog Light
Alternator power wires
Alternator regulator connector (if you are gonna use a 1wire Alternation which requires only a power wire).
Left and Right Horns
A/C fan
Little A/C fuse box on passenger side
Wiper fluid level connector
