92 tsi wiring diagram
bigbrdf250
59
Dec 9, 2011
SugarLand, Texas
where can i get a free wiring diagram at no charge. need to find some cennections for coolant tems. thanks
2.0 turbo
I tried that site a while back and had to share some info to download for free. I looked through it and still could not find the actual wire colors and pin location for the coolant sensor. Did I Miss it??
Yup. Right around page 75 of 320 in the 90-91 electrical manual, you'll find the coolant temp sensor on a turbo car.
Wire colors are listed on the diagram itself or explained on page 48 of 320.
There's also this but I don't think it will be as helpful to you: 1G ECU Pinouts
pretty sure the temp sensor just goes strait to the ecu so just follow the wires out of the sensor and along the main harness. the temp sensor in the thermostat goes up along the intake manifold with the fuel injector wiring and all that around the engine. the sensor in the radiator goes into the chassis harness i think but still ends at the ecu, not 100% on that though.
