99 gsx boosting problem
Gsxxx
40
May 31, 2014
Dry creek, West Virginia
i just got done putting a new garret t25 turbo from millerimport on my gsx. and got everything hooked up and made sure my ic piping was tight. and took her for a spin, it vaccums fine at idle around 10. but when i go to give it gas it only goes up to 0. you can hear the turbo spooling but no boost. im thinking it has something to do with my wastegate iuuno any advice would help thanks guys.
There's a little elbow on the exhaust housing of the turbo that moves the waste gate flapper. If that is stuck open, then it will eventually build boost but it will take more effort from the car. The waste gate actuator arm slides onto it. It's pretty much a "L" shaped piece on the turbo.
ok i am going to go check it now. thats all i know it could be.
it would only go to 5psi then it would start sputtering out.
