Wiring plug
just5_0
72
Feb 8, 2013
rogersville, Tennessee
Can someone ### tell me what this plug goes to it has 3 wire's 1 black,1 red, 1 blue with a red strip? The car is a 98 gst the previous owner said the car use to be a 5 speed and they changed it to a auto,and im going to change it to a 5 speed. I dont think it is a reverse light bc mine lights up when iam in reverse unless it is the plugg for a 5 speed reverse. I am going to try and put a pic of it in here just to let u see it is right behind where u put water in the rad.
Should it plug into anything? My check engine light is on but i think its bc my o2 sensors are not plugg in i have my exhaust off. What is the cas? Thanks for the reply.
Yes it looks like some one has wired it in with a connector. Does the 6 bolt motor have a cas? And what do u mean it has been converted ? Do u mean they wired in a cas plug for a 6 bolt swapp?Thank's for the reply.
no thats not a cas for a 6 bolt and yes the 6 bolt does have a cam angle sensor, but it on the intake cam bolted to the head. im not sure why else the would convert it except for a signal to start the car instead of the clutch switch when going from manual to auto.
It looks like it was converted to a 95-96 type cas which is on the intake cam gear, 90-94 and 97-99 have the cas on the opposite side of the head where you have the empty plug.
Ok let me ask another question. I looked at the auto transmission and only found 1 plugg going to it, is the reverse light plug seperate on the auto? The reason i ask is i noticed on the 5 speed there is a single wire going to it with 2 wires. Im sorry to ask so many question i am new to the dsm. Thank's for all the reply
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
