Coil On Plug Wiring
This is probably the best article you will find about fabbing up your own coil on plug. But, before you go and buy all these parts, are you doing a COP setup for the right reasons. Ask yourself this,
1: Do you own some sort of ignition system to help the COP out, such as a dynatek, MSD, or anything similar?
2: To go along with number 1, are you running high boost (over 20) lets say? Because if you are, you MAY run into problems without running a standalone and a COP.
3. Do you have problems with your current electrical system? If the answer is no, why run a COP, there are plenty of high horsepower dsms without a COP or standalone.
If you answered no to any of those questions, then you may want to rethink building a COP.
Either way, here is you article.
http://www.dsmtuners.com/forums/art...5-coil-plug-wiring-install-pics-part-1-a.html
James :laser::talon:
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
