wiring help
For the first plug, the last three that come from the line of wires that goes under or next the fuel rail are the cam angle sensor, crank angle sensor, and the last goes to the AC compressor. I am unsure of the first two I listed order but the colors should match the sensor plugs. The last one is the longest and goest to the AC compressor.
For the second plug I can check tomorrow which one the white plug goes too, but off hand some things that plug in that area are the ISC, knock sensor and O2 sensor.
I figured them out. The first plug goes to the evaporator solenoid. They second is my profec boost controller.
