radiator fan wiring help
mattsGSTeclipse
204
8
Dec 20, 2005
Lewiston, Maine
Ok so I'm in the process of doing another wire tuck. This time I was to eliminate some of the stock fan wires. I removed the a/c fan wiring, now I need to remove what I don't need from the stock main engine fan wiring. I'll be using an aftermarket electric fan so it will only need two wires. What wires do I need to keep?
I notice the fuse box has high and low relay(?) for the fans. What one(s) would I keep? Thanks
your radiator fan wires have two steps and four wires. the aftermarket only really needs the black and blue wires. but you can keep all four if you want. just wire them together with the correct polarity so you don't fry anything.
there is an article in the FAQs, but basically wire the hi AND low to the fan power wire, so it is turned on at ANY signal.
