wiring diagram and bad idle
metalx
Aug 22, 2011
modesto, California
hi i have a 95 ecplise rs v4 non turbo stick shift. i have a problem with my idleing. but i found a wire that is unpluged and i cant find the place for it so im looking for a wire diragram for my car.
how to fix bad idle - YouTube
video i took that shows what the car does and shows the wire. if its hard to see the wire is right next to the ecu and kinda hangs on top of the tranny. thanks
O2 sensor, I had a 95 Integra that did the same thing and as for my 2G it was an idler screw issue. Possibly check both sensors are connected and fully operational and if not that locate your self a Chilton manual - very helpful.
As for the connector, I can't tell from the location... sorry. But I'm pretty sure it sounds like you have a O2 sensor problem.
