Wiring Cam sensors
4g63telantra
454
Dec 10, 2004
Toronto,
I have a 1990 CAS harness and a 91+ Cam sensor
JUst wanted to know what wires hook up to each other (from harness to sensor)
90 Harness goes like this in order
Black-Red-Yellow-White
91 Cam sensor
Black-Red-Black-White
So would I have to hook up the yellow wire into the black wire on the sensor?
4g63telantra said:
91 Cam sensor
You sure the second "Black" wire is not just the yellow wire baked and covered with grime?
I'd clean it up / follow it back to the plug side to make sure.
BTW.. my 1990 has a square plug for the CAS at the firewall. Not sure of the 91-94s but my Chilton's :rolleyes: shows it as a flat plug :dsm:
